Clublog update
HB9ETR
Re: Clublog update
Post by HB9ETR »
yes, sure..
I get a "Y" in the update column and if I go to Clublog I can find the QSO.
On manual, I get a "N" and cant find the QSO on Clublog.
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
HB9ETR
Re: Clublog update
Post by HB9ETR »
I downloaded and repaired my install and now all is ok.
tnxs for inputs
Rob
HB9ETR / G0IFL
Re: Clublog update
Thank´s for the informaton :D ;)
Re: Clublog update
The error reported is a timeout:
Code: Select all
2014-08-23 10:27:06.6239 ERROR: *** ClubLogManagement: Upload to ClubLog caught in error ******* [Function: sendLogThread_DoWork] System.Net.WebException: [color=#FF0000]The operation has timed out[/color]at LogOM.BL.ClubLogManagement.DoSend(QSO qso, String url, String email, String callsign, String password, String apiKey)
at LogOM.BL.ClubLogManagement.sendLogThread_DoWork(Object sender, DoWorkEventArgs e)
2014-08-23 10:27:06.6289 ERROR: *** ClubLogManagement: upload caught in error with code:
It seems the answer from clublog requires an higher timeout or website was busy...
NN7D
Re: Clublog update
Post by NN7D »
One thing I have noticed with Clublog is their update to where you can see an addition to your log on Clublog.com is very slow. I can do the right click on a log entry and add it to Clublog, with no errors, then go to Clublog and the qso is not displayed for some time. I can re-add the same qso, and the Help/Show Log report will show a dupe, but still no update in the displayed Clublog log. If I come back in several hours, the updates are displayed. So they must have a back-end which is updated immediately, but their front end which displays the log online, is slow to get the updates, which makes it challenging to troubleshoot.
Doug
W7DRM
K7PT
Re: Clublog update
Post by K7PT »
It's like what happens on LOTW, takes a while in the Q before you see it in your Recent QSOs.
