Wrong DXCC field value on ClubLog
IK4OMU
Post by IK4OMU »
Hi all,
I have manually inserted in Log4OM 3 QSOs with 7P8RU but on ClubLog the DXCC field is recorded in a wrong way while, for example, on HamQTH the country name is right, Lesotho.
Is it because of me or about my program settings that the data are transferred wrong to ClubLog?
Note: do not pay attention to the time of the last 2 QSOs, it is the same but it was my mistake to have left it in manual instead of automatic when I inserted them in Log4OM
73 - Maurizio IK4OMU
Re: Wrong DXCC field value on ClubLog
What country name is recorded in Log4OM?
IK4OMU
Post by IK4OMU »
In Log4OM it's Lesotho.
Note: in Log4OM I have corrected the time of the last QSO after it has been uploaded on ClubLog
suggest that you check if you were in sat mode when you saved the QSO's
IK4OMU
Post by IK4OMU »
If you mean the "SATELLITE MODE" checkbox, it was unchecked.
Could this be something that has happened before?
https://forum.log4om.com/viewtopic.php?t=5516
Also in my case the CAT was disabled when I manually entered the QSOs
Unless your using a very old version of Log4OM that was fixed in 2.7.15 you should be using 2.17
However the fix might be the same, try a bulk upload with clearing the Clublog data
IK4OMU
Post by IK4OMU »
I solved it as you wrote.
I'm using the 2.17 program version.
The adif exported from Log4OM for that QSOs has differences between BAND and BAND_RX fields values.
I edited it before uploading it to ClubLog.
So it seems we stopped the freq issue but not the band issue will add it to our Mantis list
RX band is set only when explicitly set (when CAT is not connected)
If you set a RX band while in manual mode, it will be kept until you remove it.
RX Band is user selectable and accepts also a BLANK value. If a non-blank value is set it will be kept...
I've made some checks on that but everything seems ok to me. Can you please give me more info?
IK4OMU
Post by IK4OMU »
I did not set manually the RX band.
However it may have happened that I turned on and off the CAT more time.
Could it have happened that in manual mode the RX band has been kept so as was the last time CAT was on?
