Log4OM 2 not uploading to QRZ anymore
m0ppr
Post by m0ppr »
Hi All,
Please see all 3 attached pictures. Last Sunday (26.03.2023) my LOG4OM 2.27.1.0 stopped uploading QSOs to QRZ on the go - I have XML subscription from them. Before that day everything was ok. I spent ages looking through settings and all looks ok. Since the problem begun the only one way to do it quite quickly is to use the QSL manager, select missing QSOs and select them for uploading to QRZ. It shows that all is ok with my credentials for QRZ. Anyway, LOTW is being uploaded without any problem. The same - the eSQL is being uploaded with no problem at all. Just QRZ is a problem. I am going to upload my settings which **I think** are relevant to my problem. Please let me know if there is any other setting I could miss.
I have to confess that I was playing with the settings of the QSL manager last Saturday and Sunday but I do not think I did something wrong.
Can anybody help please?
01 - qrz-problem.png (110.29 KiB) Viewed 3075 times
02 - qrz-problem.png (108.86 KiB) Viewed 3075 times
03 - qrz-problem.png (175.42 KiB) Viewed 3075 times
m0ppr
Re: Log4OM 2 not uploading to QRZ anymore
Post by m0ppr »
Anybody? :)
Ft8 qsoo's or ssb
m0ppr
Post by m0ppr »
Hi, thank you for answering. Ft8, I do not use ssb or CW. WSTJ sends QSOs to log4om with no problem. Then log4om used to upload QSOs to QRZ on the go like every few minutes, but few days ago it stopped. I realised log4om creates a log file but I have not found any single error inside if the file.
m0ppr wrote: 31 Mar 2023, 04:25 Hi, thank you for answering. Ft8, I do not use ssb or CW. WSTJ sends QSOs to log4om with no problem. Then log4om used to upload QSOs to QRZ on the go like every few minutes, but few days ago it stopped. I realised log4om creates a log file but I have not found any single error inside if the file.
This notice was published in this forum and across all social media sites - You must delete the existing UDP connections and re-install them
viewtopic.php?t=8260
m0ppr
Post by m0ppr »
Thank you. I tried to search the forum but i did not see this warning. I will try after work, many thanks!!!!!! Looks very promising!
YO4DG
Post by YO4DG »
Hi to everyone
I resolve the problem without delete my UDP. Just click EDIT, then check you want in the submenu, then SAVE. All done.
So, first click Edit in the Connections (see image below)
Then click what you need (see image below...my choice)
Verify if the UDP is checked, then save.
Good luck, Gabriel
YO4DG
m0ppr
Post by m0ppr »
YO4DG wrote: 04 Apr 2023, 09:31 Hi to everyone
Good luck, Gabriel
YO4DG
Your solution works! Thank you :)
