Hi
I have been using Log4OM for some time now great program
But since I updated to Version 2.28.0 a couple of weeks ago it has stopped Adding the QTH and Address and other details to the logged contacts
Also it no longer uploads them to QRZ - LOTW - Etc I have to manauly upload then from QSL Manager at the end of the session.
I have changed nothing and it worked great until I updated to latest release.
Is just me or is there a bug in the last version
Using Wimdows 11 and that is working fine on all other programs so I knw its not a PC but a Log4OM issue
I am not a novice on Computers so have double checked all setting on Log4om and reseaved etc. but it still no change.
All started from last update of program
Anybody any ideas.
Phillip GM4SUF
Not logging all info since last update
- log4om.png (15.58 KiB) Viewed 824 times
Re: Not logging all info since last update
Phillip,
You must not have DELETED and then REBUILT your FTxx UDP Connections.
Well noted in the Release Notes, User Guide and on many threads here in the Forum.
Major changes were made with a V 2.27.xx.xx release where it was required to delete the existing UDP Connections and Rebuild them due to extensive programming changes.
Check out this link: viewtopic.php?t=8260
Phillip,
Its not a bug because I just tested using your call and it worked fine, see below
Before you save the QSO is the lookup showing the address and QTH details in the F2 window? and is the QRZ image displayed?
Try re-entering your call sign and QRZ password in the infor proveders section of program config and click the button to test lookup, do you get a green check mark?
Have you checked on QRZ that your logbook expiry date has not been exceeded?
If its an FT8 problem folloew Nolans advice
Let me know how you get on either on here or by email
HI Terry
Yes checked all p/w etc
Yes look is working on Lookup F2 See screen shot just not saving it.
if I go in to QSO manager tagg all the blanks ones and then click un update it looks them all up and fills in the blanks.
The IU4DAF I updated via QSO Manager
The YL2KF and WD5CFM are just as logged, once done QSO Update all data was filled in
I did a fresh instal on our Clybs PC today and it is ding the same thing and is same version.
Hope that helps
I will re buld links tomorrow
Phillip
Hope that helps
Phillip
- log40 2.png (79.09 KiB) Viewed 796 times
Ahgggr!
They are ft8 QSOs you should follow the information from Nolan in his post
We had to update udp protocols which required user intervention when updating log4om it was documented on social media, in the user guide, on this forum and in the release notes - I guess you missed them.
